I can't get the two terms to add up. i can get the results individually. Attached is Mathcad 15 sheet. Thanks
Avoid inline evaluations.
Define the variable and then evaluate it in a separate region:
Thank you, Werner!
Prime 9 converted.
Thank you, ttokoro!
