On 7/17/2009 5:56:23 PM, ArtZ wrote:
>Jean,
>I am using glycerol/water
>mixtures as a stable, variable
>thermal load.
>You may recall that
>previously, a worksheet with
>thermal conductivity versus
>mass fraction was posted.
>Recently, I obtained data on
>heat capacity versus glycerol
>mass fraction.
>With the addition of the
>boiling point versus mass
>fraction, I can customize my
>thermal loads for all three
>parameters.
>Art
_____________________________
Art,
I'm trying to understand that given a volume of glycol p2 you want the temperature of the mixture as function of the variable p1 volume of water.
![](/upload/Art_Unknown26.gif)
Does it make sense if you put correct b1, b2 as per handbooks ? The linearity depends upon b1, b2 (which I don't have off hand).
Jean
