Boiling Point Elevation
azikorus-disabl
Collab,
I am trying to calculate the elevation in boiling point as glycerol is added to water.
On the attached worksheet, I attempted to work from an online example by have a problem with the units.
Also, the expressions do not allow for very high concentration of glycerol in the calculation.
Any comments would be appreciated.
Art
21 REPLIES 21
1.Incorrect units.
Temperature elevation constant must be 0.521 C/mol/kg
Viktor Korobov
Viktor
... and water boiling point (at normal pressure) is not 100K but 373.15K (100C)
Val
http://twt.mpei.ac.ru/ochkov/v_ochkov.htm
1. Incorrect units.
Temperature elevation constant must be 0.521 C/mol/kg [Viktor]
2. ... and water boiling point (at normal pressure) is not 100K but 373.15K (100C) [Val]
3. ... boiling point(s) are function of absolute pressure
... the formulation does not look correct [jmG]
Thanks All,
Viktor's unit correction seemed to be the issue.
There still is an issue as the concentration of glycerol approaches 100%. Does anyone have any thoughts on that?
Art
On 7/15/2009 12:11:05 PM, ArtZ wrote:
>Thanks All,
>Art
_______________________________
The issue is that the formulation is incorrect. A problem of same nature as: how much to mix component of x% with component of y% for a resulting z%.
jmG
Art,
Work directly in Engineering system.
jmG
>Thanks All,
>Art
One picture for this subject:
Val
Glycerol-water mixtures: Boiling points in attached.
Viktor Korobov
Viktor
..and saved in MC11 format.
Viktor Korobov
Viktor
>Viktor Korobov
Tanks Viktor,
Recreated in 11,
as your saved 11 version is scraped
but could be recuperated !
jmG
Art,
Here is saved 2001i.
Jean,
Thanks for recovering the file. I have MC2001i and MC13 and couldn't read Viktor's files at all.
Did Viktor cite his source of data in his postings?
If the glycerol mole fraction is 100% wouldn't that represent the BP of 290�C? Seems the x scale is reversed.
The funny step as the glycerol mole fraction --> 100% doesn't seem correct. I'd expect a smooth transition.
Since I am working in mass fraction, I'll need to convert from mole fraction.
Art
On 7/16/2009 1:41:21 PM, ArtZ wrote:
>Jean,
>files at all.
>smooth transition.
>from mole fraction.
>Art
Sorry, see revised variant.
Viktor Korobov
Viktor
Art,
This work sheet 2001i, is Viktor in mol fraction,
with a slight correction on the 'x' marker.
Jean
Jean/Viktor,
On the attached worksheet, I have converted the mole fraction values from Viktor to mass fractional.
I was surprised to find that the relationship between mass fraction and boiling point is likely linear.
Viktor, where did you get the mole fraction values versus boiling point.
Please let me know if I didn't do the conversion correctly.
Art
>I was surprised to find that the relationship between mass fraction and boiling point is likely linear<<br> _________________________
The question is really what are you looking for ?
Jean
Jean,
I am using glycerol/water mixtures as a stable, variable thermal load.
You may recall that previously, a worksheet with thermal conductivity versus mass fraction was posted.
Recently, I obtained data on heat capacity versus glycerol mass fraction.
With the addition of the boiling point versus mass fraction, I can customize my thermal loads for all three parameters.
Art
On 7/17/2009 5:56:23 PM, ArtZ wrote:
>Jean,
>thermal load.
>You may recall that
>mass fraction.
>parameters.
>Art
Art,
I'm trying to understand that given a volume of glycol p2 you want the temperature of the mixture as function of the variable p1 volume of water.
Does it make sense if you put correct b1, b2 as per handbooks ? The linearity depends upon b1, b2 (which I don't have off hand).
Jean
Art,
I think your mole/mass conversion is wrong. See attach.
Viktor Korobov
Viktor
Viktor,
Thanks for your post; that is a lot work! I am just now looking at your worksheet and don't completely follow what you have done.
From your work, it appears that boiling point is very non-linear.
I may have asked you in an earlier post and you may have responded, however, could you name the source of your original boiling point versus mole fraction data?
Thanks again,
Art
>versus mole fraction data<<br>
That complicates matter, just go by my formula. It does the mole fraction algebraically, look at the formula again where you simply put the weight or the mass if you prefer. The formula is the "homographic function", one form of it, an expanded form of 1/x. For sure it is not linear, it is of the reciprocal form, i.e: a rational fraction. Also, you must understand that you need the specific heat capacity of each component.
Just reproduce the attached, fill-in the respective data.
Jean
