What you are seeking is not possible in Prime except using a technique presented by ttokoro
It is possible to use links to different worksheets that could contain different inputs but these need to be manually selected.
Create some text in a text box highlight it and go to Text Formatting | Links on the menu.
When you control click on the links or right click and select open the linked sheet opens.
An example from Roark's book where the splash screen links to the contents page
Cheers
Terry
I think my question was not clear.
Essentially I want to be able to present different "blocks" of input pages depending on the selection.
So if I select X then present one set of inputs.
If Y selected then another set of input options is presented.
Like a dynamic show/hide ??
Cheers
Terry
