Copy/Paste issue with MathCAD 8.0
TP_10251883
I typically do all my work in a textbox and recently I cannot copy equations and text together and paste below inside the textbox. I would do this all the time but now it doesn't work. I can copy from a textbox and paste outside the text box, but this is inconvenient.
Anyone have any insight into why this may be happening now?
Thanks.
34 REPLIES 34
CS_7175918
(To:LucMeekes)
The previous post had indicated that PTC were aware of the issue and would have it fixed in MathCAD Prime 9.
PTC haven't fixed it.
I wouldn't expect software this expensive (for those that have paid-for licenses) to need OS patches to make it work properly.
according to https://www.ptc.com/en/support/article/CS384330 the fix is planned in Mathcad Prime 10.0.0.0 (in March 2024 ?).
To confirm this information I suggest you to open case at PTC Support.
Martin Hanák
Thank you! It works!
(It's strange, but it didn't work out the first time - I ran scripts, installed updates, but it worked only after the second register edit)
Not working for me now.
I had my M Prime 8 and 9 working using the workaround suggested but in M Prime 10 it stopped working (with or without workaround)
After sharing this issue with PTC support, I have to clarify that the problem is not something that was working in version 9 and not working in version 10.
