The attached Mathcad 15 worksheet (hopefully more folks can open this instead of Prime 3.1 format) is being created to determine the shear, moment, slope, and deflection of a simply supported beam. Towards the end of the worksheet I am attempting to create a vector that includes the point loads (y), distributed load start points (zs), and distributed load end points (ze). Is it possible to write a function that creates a vector with a total length of the sum of these smaller vectors and sorts the values by increasing length? The points in this vector give the points where the moment function is discontinuous .The total length of the vector will change as the number of point loads and distributed loads change.
Once this vector is created I'd like to use it as integral bounds to determine the centroid of the moment function between discontinuous points. Is it possible to set the vector and the vector +1 as integral bounds?
As always, thank you for your help.
Thank you Richard, this is great! Is there a way to suppress excess 0s in the case where one of the loads is 0 such as in the attached?
Additionally, is there a to multiply the centroid function by another function, valve by value? It appears the vectorize function won't allow this.
Yes, by deleting them ![]()
Your Reaction function? The problem is the inline evaluation. You can't have that with a function definition, because there are no values to display.
Thank you Richard, currently the Centroid function excludes the outer values in xx. In this example it calculates the centroid between x-values 1 and 4, 4 and 8, 8 and 11. Is it possible to modify it such that it also calculates the centroid between 0 and 1, 8 and 11 (or any future extreme values)? I’ve tried changing the values of i but am only able to capture one of the two extremes. As you can see in the attached, trying to capture both cause the Centroid function to error.
Additionally, is it possible to create a function that uses each successive set of two values from vector xx as bounds of integrations, for example and integral from 0 to 1, 1 to 4, etc.
The problem seems to be a bug. If you define a range variable from 0 to last(xx)-1 it works (assuming you get the other indexing right). But if you add an inline evaluation to that range variable, it fails. The solution is to not use inline evaluations with range variables.
Most things are possible ![]()
Thank you very much Richard, this is very helpful!
