Custom Functions
terryhendicott
Custom Functions
Hi have successfully compiled the multiply(a,M) example custom function but have a few questions.
Q1> Do you compile for x86 or x64 seeing as PTC Prime is 64 bit?
Q2> Where do you find the custom functions as neither the Prime menu or the search for all functions has a section for custom functions?  Mathcad 15 search had a specific spot.
Cheers
Terry
Q1: The help info isn't very clear about it. Probably because most of it was copied from real Mathcad, which was a 32-bit app and at that time 64-bit was far away.
I think with a 64-bit app, the DLL's you want to attach/include should also be 64-bit. But you can try if it works with 32-bit (x86) compilation and linking.
Q2: Ever tried the Prime System variable CustomFunctions?
Thanks heaps Luc
Cheers
Terry
