Diffrent IP-RAnge
zed
Diffrent IP-RAnge
hello,
i have an flex license Server that works great, but i can´t establish a connection from a diffrent IP-Range. But i can establish a RDP Session. I´ve deactiveted the firewall but the client don´t get a license.
MikeArmstrong
(To:zed)
You might be able to find something useful here.
http://communities.ptc.com/docs/DOC-2354
hello Mike,
thank you for the quick answer, but my Server is running. I can´t use the Licensing Service from antoher IP-Range
The Server has the IP X.X.220.34 an only clients from the X.X.200.X network can´t establish a connection. The Server can be accessed by serveral other protocols like RDP, Ping. I even have access to the share.
MikeArmstrong
(To:zed)
Unfortunately that is a little out of my knowledge (which isn't hard ). Maybe you will be best contacting PTC.
already done but thanks for the help
MikeArmstrong
(To:zed)
I hope you find your answer.
Please report back if you get a solution to close the thread out.
