Enable / disable overwrite warnings?
MichaelW
Hello
is it possible to enable / disable a warning if an expression overwrites an existing / predifined function or constant?
Such as c:=4 should warn you to then overwrite the Light Speed constant.
The was as seen in Mathcad 15
RichardJ
(To:MichaelW)
I assume you mean "can you do this in Prime?".
No. One of the many missing features. That's why most of us stick with Mathcad 15.
VladimirN
(To:MichaelW)
Hi Michael,
In main menu you need to select "Tools" --> "Preferences" --> tab "Warnings" --> uncheck "Show warnings on redefinitions of":
RichardJ
(To:MichaelW)
MichaelW
(To:RichardJ)
You are right. Its about Prime 3.
I miss that functions and other functions too
