Get Extremes
Jbryant61
Get Extremes
Is there a way to modify the "Get_Extremes" function that Richard kindly shared so it will work with both sets of data.
I tried using Ksmooth as Jean has recommended many times before, but it doesn't work for both data sets.
thanks
Jason
RichardJ
(To:Jbryant61)
The solution to noise is not smoothing. That distorts the data, and you are finding the extrema of the distorted data. Here's a more robust algorithm.
Richard
Jbryant61
(To:RichardJ)
Thanks.
Jason
