Help solving for a variable
agarrea
7-Bedrock
I am new to Mathcad and having issues getting the program to solve for a variable. I was able to get my first equation to work, but when I tried plugging that value into the second equation I started having issues. The program would not let me plug in my value and solve for D. What am I doing wrong?
7 REPLIES 7
(To:agarrea)
Not sure if I guessed correctly what you are looking for.
Would the use of a solve block or the root  command as shown in the picture help?
(You can't expect a solution if f1 is negative as with the first set of values you provided)
The graphic solution/verification will bee good too
Thank you!
I tried doing what you did and it is still not working for me
(To:agarrea)
1) You have to use the Boolean (comparison) equal sign when you write an equation, not the evaluation equal sign as you did.
2) I changed back L from 0,56 m to the 56 m as in your first sheet as Mathcad can't find a solution with L=0,56m. Chances are that there is no solution with this combination of values.
Find attached the working file in Prime 5 format.
Thank you so much.
LucMeekes
(To:agarrea)
