Help turning textbox inputs into matrix
ptc-5105545
I am trying to create a matrix of numbers from a textbox and having a little trouble doing it. I would appreciate any help I can get. I have attached a sheet with my problem.
Thank you!
35 REPLIES 35
VladimirN
(To:Werner_E)
Here everything is fine:
(To:VladimirN)
Fine, so it seems we have a way which works on all Win versions.
Without VBScript:
It works with a TextBox, WebTextBox and Prime.
or so:
only the first comma is replaced, otherwise an error is thrown anyway if we have multiple decimal colons.
With trace?
Valery Ochkov wrote:
With trace?
Ooops, not really.
So it gets even shorter by one line 😉
