Hi Mathcad Community,
I’m working on a problem involving a box cross-section. I need to plot the shear flow distribution q(y) along the height (y). The plot should be linear in the flanges and parabolic in the webs, but my current plot is a step function and doesn’t match the expected values. Can someone help me redefine q(y), and provide the correct Mathcad function to plot a continuous shear flow distribution?
Thanks for your help!
Like this:
Maximum stress is at the neutral axis in the webs at 4.682 MPa
Your qI, qII and qIII are constant values, so you can't expect anything else but a step function.
I guess you will have to torn these variables into functions dependent on y to see a different plot.
E.g. you have to define what the q-value for example for y=110mm should be.
The way you defined is at present is that its 14.844 N/mm, the (constant) value of qII.
Like this:
Hello @engr_mkhalid,
It looks like you have some responses from our community champions. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
