Hide Variable in Prime
ptc-1299962
3-Newcomer
I would like to hide the variable name and only show the result of an equation.  I've seen several ways to do this in MathCAD 15, but we've switched over to Prime.  Is there a way to do this in prime?
For my specific application I'd like to show the result of a previously evaluated equation in line with some text so that my wording incorporates the result of my math.
6 REPLIES 6
It is about the implicit operatot?
About "explicit" and "clear.sym" function to clear the symbolic values of all variables: https://support.ptc.com/help/mathcad/r7.0/en/#page/PTC_Mathcad_Help%2Fexample_explicit_calculation.html%23
Could you post an M15 example of what you'd like the output to look like?
Stuart
(I sometimes use the format function to do what you are requesting, but the display of strings makes it look "ugly" - which is often fine, but sometimes quite annoying to look at, as this Mathcad Express 7 worksheet attempts to show:
97323a068a3897ae22734b4e6074bc0b
He don't want much, do he?
What I would like to do is, in Stuart's example, is omit the str(a,0)=  and only include the "my simple variable v has the value 9.99, which "is" nice".  That way you can include results naturally in a text field without the somewhat distracting variable name.  I think this was possible a couple of different ways in 15.
@StuartBruff wrote:
(I sometimes use the format function to do what you are requesting, but the display of strings makes it look "ugly" - which is often fine, but sometimes quite annoying to look at, as this Mathcad Express 7 worksheet attempts to show:)
Forgot to add that the internal quotes are fairly easy to get rid of if you're willing to roll your own string replacement function
Stuart
And another thing ... a positive for Mathcad Prime 7.
I'm sure that the amount of mandraulic effort I have to put into formatting my way out of display horrors is the root cause of my current bout of Kardashev Type I Hyperbubonic Man Flu,  🤒👿
Stuart
