I have been using Mathcad 15 for a long time, and have many programs in it. Now that it has been abandoned by the company, can I get a working copy or get an up to date license? I do not want to move to Prime, just to keep using my existing MathCad 15.
Regarding Prime 7's built-in converter, Prime 8 will have a "save as HTML" option in the converter for Mathcad 15 worksheets, which is our official workaround for being able to look at Mathcad 15 worksheets before converting them without needing a Mathcad 15 licence.
We'll have a video about this soon after Prime 8 launches in March.
As long as you have a license file for MathCAD 15, it will function for a few more years.
What you may not do is get a new license to MathCAD versions prior to Prime7.
It seems that Prime 7 is a lot better at converting Mathcad 15 files than the old Prime 3.0 which I had. So I will bite the bullet and get and try out Prime 7, even though it is a yearly subscription now. Many thanks to the responders.
You sure know that you can test drive Prime 7 with full functionality (including conversion of legacy files) for about a month before it falls back to the limited Express mode. So you can see if you are happy with Prime and the converted files without any risk.
Otherwise you sure should nag PTC to fix your MC15 problem as its not normal behaviour to have a new license generated every month.
Mathcad Prime 7.0:
https://www.mathcad.com/en/try-and-buy/mathcad-express-free-download/install
https://free-dl.ptc.com/install/pim_installmgr_mathcad.exe
P.S. In March, the release of the 8th version is already expected.
"We'll have a video about this soon"
https://www.youtube.com/watch?v=BBcsHHb00Xc
