How do you convert a table of values which is in rectangular format to polar?
wksriaanc
3-Newcomer
See attached table with values in rectangular format using Prime 5
6 REPLIES 6
Too easy 🙂 Thank you, ValeryOchkov. P.S. User's that has previously used Mathcad 15 reckons it's more user friendly. I find Mathcad Prime easier to use?
Some thing is better in Prime, some - not!
We can use Re and Im functions in Mathcad 15  and Prime too!
Can I just ask one more question. Sometimes I want to define a numerical with a string. See attached. Can this just be overcome by typing, value:=1
I'm not clear about what you are actually trying to do from that image.  Mathcad doesn't automatically coerce values from one type to another (with a few exceptions).   Mathcad does, however, provide a few conversion functions.   In particular, you may like to look at the function str2num to convert a string to a number.   num2str does the reverse.
Stuart
(To:wksriaanc)
Yes, because what you call a string actually is a variable name and if you use a variable it has to be defined before. Obviously you can't multiply a number with a string.
You may consider labeling that variable as unit and you can also type it in the placeholder for the unit when displaying a variable.
