As per the original post..
Hello. Can you help me to convert this file to MCDX? Thank you very much.
Here you are. File is in Prime 6 format so you should also be able to open it with Prime 7 or Prime 8.
Current Prime version come with a converter which does not need a Mathcad 15 installation. So you can do the conversions yourself, too.
Thank you.
