@LucMeekes wrote:
Mathcad /Maple will not be fooled:
If you evaluate that numerically, it says 2048,
but that's due to poor (with respect to symbolic) numerical precision,
similar to the numerical results I presented above.
Yes, I'd expect that. However, I do note that Tetsuro specifically mentioned Prime 7.
If, as I implied by my mention of infinities, you plug in -∞ to the expression in Maple you get 2048 symbolically (at least, in Maple Flow you do).
(Mathematica gives "Sum[2^n, {n, -Infinity, 10}] = 2048", as well. I would hope Mathcad Prime 7 gives the same result?).
Stuart
(Of course, there's the thorny issue of whether -Infinity counts as an integer)
@ttokoro wrote:
2^11 is 2048. How to find a and b? a and b are integers.
AFAIA, the binary expansion of any integer is unique.
Stuart
Prime 7 shows another a and b.
Given the Puzzles and Games Label, I thought it might. 😈
Stuart
Can you upload your worksheet?
Хорошо. I've modified it slightly to make it more self-contained.
Stuart
Edited to add: Why is it I only notice mistakes *after* I've posted something? 🙂
The original image had the type of the function num2base as returning a String; this was because I copied the function from another worksheet where it made more sense to return a string and I forgot to change the type when I modified the function. Ridiculum est me!
Hmmm,
Never expected this would happen.
But then, if b is a positive integer <10 then a is complex
for b=10 I get an exception due to trying to take ln(0).
for b=11 , a=11.
for b>11 a is a positive real.
Ah! b=22 gives a=23 (numerically), but:
And with every higher multiple of 11 for b you get closer to a being b+1. for b=1012:
and you don't even need multiples of 11 anymore. For b=1013 the evaluation gives:
But at b=1023 the numerical evaluation fails.
Neat.
Something else that occurred to me in my sleep-deprived state early this morning, but which I promptly forgot about until now, was based on one of the many peculiarities of infinities.
(a = -38 does the trick numerically, but I wanted to give the impression of a really large number)
I don't have a symbolic processor to hand to check its result ...
Stuart
Stuart
Yep, here you are:
I'm afraid infinity, nor its counterpart -infinity counts as an integer. Small test:
If its equal to itself plus 0.5, then it cannot be an integer:
Many thanks to all mathcsd masters.
My another answer is Stuart's one.
Fourier series of non-sinusoidal wave forms sometimes have infinity Fourier series.
Such as rectangular wave of magnitude 1 shows it as follows.
The RMS value is 1. And Mathcad can show it.
And in this case Stuart shows
This is 1111111111.11111111111111111...
Mathcad never was able to solve diophantic equations and the symbolics ever so often ignore an "assume, xxx=integer"
You probably are aware thats its quite easy to manually arrive at the unique solution a=b=11.
Given that the sum is
with a<=b<=11, you can do as follows
Somewhat shorter:
But the shortest sure is Stuarts remark about the binary representation of a number being unique.
