How to make the formula vertical alignment?
I have some formulas like the picture below, how to make the formula vertical alignment in one vertical line?
Now i use "Tab" key in keyboard, but it is not convenient.
The alignment tools that were in Mathcad 15 were not deemed worth including in Prime. (It has been requested. . .)
The only way to align things in Prime is (AFAIK) to select and drag them.
Thanks very much for your help.
