I am getting error as 'All evaluations resulted in either an error or a complex result'
vveeran
Hi all,
I am trying to plot the graph for vm = 1, 2.
But, I am getting error as 'All evaluations resulted in either an error or a complex result'
when I plot for f(x) vs x.
When I do the same program in Matlab for vm = 1, 2, I can able to get the result with no error.
My question is, in mathcad, is it difficult to plot for vm = 1, 2 ?
I attached my code below.
Could someone help me.
You are right Werner.  Careless of me!  I've attached corrected file.
Alan
8 REPLIES 8
-MFra-
(To:vveeran)
Needs to be expressed as in the attached.
Alan
(To:AlanStevens)
But what vetri had typed was not the b-th root but b times sqare root.
Not sure what he meant, but I guess you guessed the correct interpretation.
However, in the first form, b must be an integer.  In the second form this is not necessary.
Alan
(To:AlanStevens)
Yes, sure, the b-th root would have been wrong anyway, as b is not integer.
But what vetri originally wrote was something like
but I also guess it wasn't meant that way.
Alan
(To:AlanStevens)
Nevertheless I think your first attempt is what vetri meant 😉
But now he has the choice
vveeran
(To:vveeran)
Dear all,
Thank you for your comments.
