I have created an eBook with an index. It is not owrking as expected. When I go to seach, the locations are missing the first letter. nver quite sure if the correct selection was made. Any ideas on how to correct this
Can you post an example?
Mike
Mike,
All I can post is an image from the search.
Thanks for the help
Sorry David,
I'm afraid I won't be able to solve the problem from a screenshot only.
Mike
David,
You can read about the creation of E-book in Mathcad in the Help file "Mathcad Help" (key F1), section "Other Resources" -> "E-Books and Extension Packs":
I have been following the instruction from the Author's Reference guide. Attached is the:
The index.txt is after it was sorted using Word.
Thanks for the support
