I have an already filled in Excel sheet with parameters and variables that I use in a Mathcad calculation. I could copy 'n paste the content to an embedded Excel component, but I'd like to avoid such menial task.
Has anybody figured out whether and how to insert an Excel component that has content?
Hello @Raiko ,
To insert an Excel component with content into Mathcad Prime, please follow these steps:
Note: To find the location to save the Excel template, right-click on an existing template file during the insert step, select 'Properties', and copy the file path.
How about using READEXCEL function?
I did that until now. Problem is that you always have to take care that the Excel sheet travels with the Mathcad sheet when handing out Mathcad calculations to colleagues. Usually I ended up helping them to find it and do half of the work for them. An embedded Excel component can't be lost (nor the reference) and is therefore much more convenient.
Hi Raiko,
(real) Mathcad, or Prime?
Excel file:
Mathcad:
Mathcad Prime unfortunately.
To explain: I'd like to insert an existing Excel file with multiple sheets as an embedded Excel component in MC Prime. I know I can copy and paste from the existing to the embedded one, but I'd like to avoid such tedious work.
Raiko
Assuming you have a full license for Prime:
what if you do the trick in Mathcad and then convert the sheet to Prime?
Hello @Raiko ,
Thank you Perez. It worked.
Raiko
