Sorry, I have asked about it here and Alan has answered. But!
I have x1, y1, z1 and x2, y2, z2.
How can I plot a line in 3D between those two points (# 7 in the picture).
Mathcad 15 sheet please!
Unfortunately, I don't have M15 anymore, so can't check, but is there is anything of use in the worksheet attached to the following message?
https://community.ptc.com/t5/PTC-Mathcad/Plot-a-Point-in-3D-Space/m-p/423663#M166095
Cheers,
Stuart
(I have no idea what's in the worksheet - too long ago for my memory to deal with!)
Thanks, Luc.
It looks like function line on page nine joins two points together (example on page eleven)
Cheers,
Stuart
(Any idea why the red is there on some items, Luc? I probably wrote the functions for M11 or M14, so there might have been some change that affected something. Either that or I was just playing around with something and was feeling too lazy to chop it out!)
Stuart,
It's definitely a Mathcad 11 file (certainly not 14, then it would have been xmcd).
I opened the area "plottools emulation" to ensure that you could see all. Errors are only inside the area.
For the plot with 'ac0' the complaint is "This is not a scalar".
Then two functions are not defined: 'fillmat' and 'reprow'. That effect ripples down, mostly because this renders the variable 'testmesh' undefined.
Other undefined functions are 'repcol', 'fillint' and also 'linspace' (which could indicate that the file was 'saved down' from 13, 14 or 15).
Sorry - no correct answer
