Hi Carlos
Regarding the intlinprog() function, Mathcad can apply an optimization algorithm that has already been developed.
Yes it can, maximise and minimise function in a solve block should work.
I ask if with Mathcad you can't write a utility or function equivalent to Matlab's sparse function?
Sparse is a definition scheme of an array that utilizes storage schemes that only contain the non-zero entries in the array. Any function that uses sparse arrays and/or matrix arithmetic using them must be written to do so. I suggest you use Mathcad's dense matrix only that may limit the size of problem able to be solved.
Cheers
Terry
