Mathcad 15
Youki
Mathcad 15
Dear all,
I got from the Mathcad cummunity a function (see attachment), which allows to list file(s) or directorie(s) stored in a directory.
Now it does not run anymore. I tried without success to work on the script. I have Windows 7 version 6.1
Can anyone tell me what happens
Thank you and best regards
Youki
Hello Youki,
there is no problem with the function. But it has been disabled.
If you look at the top right corner of the function there is a small black square.
To correct this ,
select the function then right click on it and you should get a pop up menu.
At the bottom of the menu you should have an option 'Enable Evaluation' - select this and the function should work correctly.
Regards
Andy
You would probably get a better response if you created a discussion instead of a document as users can then upload files.
Mike
