A ball with a mass of 1 kilogram is at the top of a frictionless ramp 10 meters above the ground. The ball rolls down the incline and launches from a height of 2 meters and an angle of 30 degrees above the ground.
(This picture was created in Creo.)
The worksheet should contain sufficient documentation to stand on its own; someone unfamiliar with the initial problem should be able to understand what is being calculated.
Find the Mathcad Community Challenge Guidelines here!
Prime 9 - compact and perhaps harder to follow.
Reminder to y'all that there is less than a week left in May! It was definitely fun reading the discussion here. 🙂
And if you want to be part of the discussion in the write-up for this challenge in June, get your submission in before May ends!
Thanks to everyone for participating!
And thanks for the blog write-up about this challenge! I hope other Mathcad users learn a lot from what the Community members have done here.
(And great job to those that submitted some really fabulous Mathcad Prime worksheets; we've also distributed the PTC Community badges for May 2023.)
