Mathcad Community Challenge May 2023 - Optimize Trajectory for Maximum Horizontal Distance
DaveMartin
A ball with a mass of 1 kilogram is at the top of a frictionless ramp 10 meters above the ground. The ball rolls down the incline and launches from a height of 2 meters and an angle of 30 degrees above the ground.
(This picture was created in Creo.)
  1. Create a function that calculates the horizontal distance as a function of initial height, launch height, and launch angle.
  2. Calculate the horizontal distance the ball will land from the end of the ramp.
  3. Solve for the angle that will optimize the horizontal distance.
  4. How will the horizontal distance change if this were performed on the Moon instead of on the Earth’s surface? Assume the acceleration due to gravity on the Moon’s surface is 1/6 that of Earth.
  5. Use the Chart Component to depict how the horizontal landing distance changes as a function of angle.
  6. Use a 3D Plot to show how the horizontal landing distance changes as a function of ramp height and launch angle. Assume the ball starts at a height of 10 meters.
The worksheet should contain sufficient documentation to stand on its own; someone unfamiliar with the initial problem should be able to understand what is being calculated.
Find the Mathcad Community Challenge Guidelines here!
Dave Martin - dmartin@creowindchill.com - https://www.mcaeconsulting.com
33 REPLIES 33
Prime 9  - compact and perhaps harder to follow.
Reminder to y'all that there is less than a week left in May! It was definitely fun reading the discussion here. 🙂
And if you want to be part of the discussion in the write-up for this challenge in June, get your submission in before May ends!
I manage the Creo and PTC Mathcad YouTube channels for PTC, as well as all PTC Mathcad marketing in general.
Thanks to everyone for participating!
And thanks for the blog write-up about this challenge! I hope other Mathcad users learn a lot from what the Community members have done here.
(And great job to those that submitted some really fabulous Mathcad Prime worksheets; we've also distributed the PTC Community badges for May 2023.)
