I have just brought a user defined function 'vec' into Prime which takes a single argument and converts to a vector i.e. a range variable. However, I am having an issue typing a range inside pre-definedbrackets.
In Prime this does not seem achievable.
I must be missing something here!!!
I remember exactly what you are refering to.
It seems PTC are about to do the same with PTC/USER.
Richard Jackson wrote:
I think the agenda is to go backward with a lack of forward compatibility
BTW, this topic of inconsistent handling of range variables and range values when passed as an argument to a function was discussed a long time ago. I can't find the old thread though.
Very strange behavior that it works when the range in defined within the brackets though.
I think we can all agree on that
Does anyone know the method of reporting bugs?
You will have to pay (maintanance) for the privilege to do so - crazy enough and tells a lot about PTC's view.
Only way I know of is to use the case logger from the PTC eSupport portal
Well my company no longer has maintenance - I will have to wait until the next beta testing and try and report it then.
