Mathcad programming
NM_10165576
Mathcad programming
Hello everyone,
could someone explain why i am getting different answers in the programs e and l.
Is there a way to get same output from both the programs? Does it have something to do with for loops?
the output should be like program e.
Attached Mathcad 10 file.
You need to include Res as an argument to Bewopti.
See attached MP10 worksheet.
Stuart
6 REPLIES 6
Just a note ... it is necessary to switch Page View to Draft View to see l definition on the right side.
Martin Hanák
If add Cv and change 7 to 8, then you can get same cols.
NM_10165576
(To:ttokoro)
Sorry, may be you did not understand my questions. I mean all the numbers should be same in both the programs.
Stuart
It worked. Thank you soo much.
No worries.
