Nonlinear ODE problem
ML_7720463
7-Bedrock
I am using Mathcad Prime Release 9.0 and Datecode9.0.0.0
Trying to use basic ODE solvers like rkfixed within a solve block. My goal is to solve a pair of nonlinear ODEs (intial value problem) which are not linear in the highest derivative term, using state space if possible. I need to use the iterative solver block because reducing the ODEs to standard form is quite difficult. the odesolve function cannot handle these equations. Are the basic solvers usable in a solve block for this type of problem? If so, an example sheet would be very helpful, the documentation and forums have not been enough. I have begun trying to solve the simple spring/mass system this way, before tackling the full equations, but not yet successful.
Variable undefined. Unable to form derivative matrix (odesolve).
OK, I will stop trying to make that approach work and just write a program with a solve block and my own integration routine.  Knowing when to move on is just about as valuable as getting the answer.
Please attach your worksheet to the message.
Attached is the simple sheet for spring/mass system.  I have also tried rkfixed solver with similar results.
LucMeekes
(To:ML_7720463)
As far as I know you need to use the standard solvers (rkfixed, AdamsBDF etc,) stand alone, that is NOT in a solve block.
(To:ML_7720463)
Would this help:
