Hi @bbobbs,
Try to use a different user profile for login and see if the issue persists. With this it can be narrowed down whether the issue is system specific or user profile specific.
Vipul
Hi @bbobbs,
Please share the dxdiag report of the system having issues with.
To get the DxDiag report: Click Windows Start button > type “DxDiag” in the Search box, and then press ENTER > Save all information to “DxDiag.txt
Also, are you saving the file locally or on a shared network location?
Vipul
Hi @bbobbs,
Vipul
Thanks!
