Polynomial Factorization and Simplification
JohnDoe
2-Explorer
Dear Mathcad fans,
I would like to know which function in Mathcad allows for polynomial factorization and simplification? Please see the attached example. I put a function and a simplified form of it (manually calculated). How to achieve that result with Mathcad?
RichardJ
(To:JohnDoe)
The symbolic processor does not llke degrees.
The Symbolic engine will do this for you, sometimes you will need to add additional commands (also available on the symbolic toolbar.
Andy
No you used the manually calculated result.
Try to use the symbolic evaluation with the original function (see attached file).
Oh dear I seem to be sleeping...
Next best...
Not quite what you want but Mathcad seem quite happy that it has simplified the form enough.
difficult for Mathcad to know that sin(60deg) should be displayed as (square root 2)/4; ... 61degrees wouldn't simplify in the same way.
regards
Andy
RichardJ
(To:JohnDoe)
JohnDoe
2-Explorer
(To:RichardJ)
Thanks guys. The solution of Richard is perfect.
@Mona Zeftel: please correct this in next releases so that "simplify" gives directly the desired solution without workarounds. And please add nH (nano Henry = 10^-9 Henry) to the list of units.
