Possible Solve Bug
ELSID
8-Gravel
Possible Solve Bug
Can someone verify this. I had a perfectly working sheet last month. I went in to do some text edits. When I re-saved, I got the error in the solve block (one equation one unknown. Running M14 M035.
Again, as written, this was working 15 minutes ago!
6 REPLIES 6
IRstuff
(To:ELSID)
>M035.
Seems to me that the naming of the function to be the same as the changing parameter is problematic.
TTFN,
Eden
RichardJ
(To:ELSID)
That's not possible.
You have "vel" defined as a function (of "flow"), but you are using it in the solve block as a variable.
Richard
RichardJ
(To:ELSID)
>one equation
>one unknown.
And, apart from the problem of vel being both a function and a variable, if you are trying to solve for dia then you have two unknowns: dia and flow (and if velocity is defined as a function of flow, then velocity is not defined either).
Richard
ELSID
8-Gravel
(To:RichardJ)
Then why was it working 15 minutes ago? HMMM. I'll post the whole file. This was a problem that Stuarts assisted me with a few months ago.
http://collab.mathsoft.com/read?130625,63
IRstuff
(To:ELSID)
If you disable the vel(flow):= definition, the solve block produces an answer.
TTFN,
Eden
ELSID
8-Gravel
(To:IRstuff)
That did it! I was going through my print out and I had disabled vel(flow). For some reason, it re-enabled on its own. This was my first program with functions. Still shaky with the concepts
