Problem in plotting graph in Mathcad 15
dm-3
I have data sheet created in Mathcad 2000 which is an array.
If I try to open it in Mathcad 15, the graph plotted in 2000 is not working.
Is it a bug? I have no go, have to work with Mathcad 15. Kindly suggest a solution.
Dhinesh
There is still a problem lower down the file in Vladimir's version. There is a line where G is assigned to Gi that doesn't seem to be useful, but just slows everything down. In the plots, you need to assign units to the 100 in the last term on the x-axis (as I've done) or remove units from the other term (as Vladimir has done).
Alan
8 REPLIES 8
AlanStevens
(To:dm-3)
Please post the Mathcad 2000 worksheet.
Alan
dm-3
(To:AlanStevens)
Alan,
I can send you a screen shot of the sheet considering confidentiality issues.
Sheet is not in English, its in Portugese language.
Dhinesh
AlanStevens
(To:dm-3)
I was going to load the worksheet into an earlier version of Mathcad (like 11 and 13) and see if the problem occurred there. Can't tell from the screenshot so I'm no help here I'm afraid - sorry!
Alan
MikeArmstrong
(To:dm-3)
Without a worksheet it will be impossible to find a solution. Can you try and replicate the problem?
Mike
dm-3
(To:MikeArmstrong)
PFA
Dhinesh
VladimirN
(To:dm-3)
Please see the attached file (for Mathcad 15).
We can point in Mathcad 2000 on the plot axes: from 1000 to 2000 for example.
Now we must point in Mathcad 15 on the plot axes: from 1000 m to 2000 m (with units!) for example.
I think the error is here.
Alan
