Programming issue . Fixing little program that calculates stresses
SFares
Attached is a little program that calculates the normal and shear stresses. Load P can be applied at different angles. I'd like it to report the results for the loads, angles and von Mises stress. I can't get it to run. I am also wondering if i can include the units for area, section modulus, load......
Sam
(To:SFares)
(To:SFares)
Like this?
SFares
(To:Werner_E)
Thank you so much!
i noticed if i change the area to 10 instead of 6 it doesn't solve.
i will start a new discussion about the same  sheet because i have other simple questions.
Sam
