On 9/25/2009 10:19:51 AM, MonaZ wrote:
>Your problem is most likely
>what Tom said, one of you is
>using large fonts, and the
>other is using normal fonts.
>Go to the Display setting, and
>make sure you both are using
>the same settings for font
>size. Unfortunately we do not
>handle this well in our
>current versions.
>Mona
______________________________
This is an old ergonomic request. What is "user styles ...+++", Mathcad does not instruct Windows to save. For instance, User1, 2, 3, 4 variables aren't saved as such. They are saved in the Mathcad default style "Arial". It couldn't be saved otherwise to the default TNR or the copied/pasted regions wouldn't work anymore. This is the reason why the "Mathcad power users" don't (or almost not) use more than one variable user ... just useful in long work sheets and with parsimony.
Jean
