6-Contributor
February 1, 2012
Saving State of ListBox
  • February 1, 2012
  • 5398 views
I'm wanting to save the selection in my list box when the file is saved, closed and reopened. The attached example file populates from the MS Excel file also attached. I've used these listbox controls in my MathCAD files for years and have always reset values when reopening files or set values manually. I'm noticing some discussions in the usage group that would indicate that it is possible to edit the script and have the listbox setting save it's selection when the file is saved and closed. I would appreciate your comments and suggestions.
Best answer by RichardJ
The script in the listbox needs to be changed. See the new versions of the worksheets here: Saving the state of controls.zip
See: Saving the state of controls.zip
If you use controls you might also be insterested in Extra Components.mcd
entec26-ContributorAuthor
6-Contributor
February 1, 2012
In reviewing these listbox examples, they are populating from script strings can the script be edited to allow population from an input table?
Look in the "Extra Components" worksheet. Look for "dynamically filled listboxes".
