The content you are trying to access is permanently deleted.
I'm trying to rewrite function "f" in the first line of the picture below in terms of only "x2" and "x3":
Find f(x2,x3)
Any ideas ? Is it possible ? Thanks in advance.
Att,
Ricardo S.
As it seems that you tried to use a solve block with "find", here is another approach
OK:
x1(x2,x3):=x2+x3
f(x2,x3):=x1(x2,x3)+x2+x3
Would essentially become: f(x2,x3):=2*x2+2*x3
Then if (also): x2=x1+5*x3, it would mean that x2=x2+x3+5*x3, so 0=6*x3 and x3=0 and finally this means that
f is not a function of x3.
Does not make sense.
What exactly do you want?
If both condition have to be considered, as Liuc said, this would mean that x3=0 and x1=x2 and f(x2)=2*x2.
Even with other conditions - if you apply two independend conditions, f would only be dependent on one variable, not on two.
Here are two ways to do it with one condition - not sure if thats waht you are looking for:
