11-Garnet
July 6, 2017
MathCad 11: how to make the result shown in line with the equation like y:=2x=
  • July 6, 2017
  • 7333 views
Good luck with the new forum to begin with (For now it works like the first MC Prime Smiley Tongue with basic errors, namely certificate errors: needed to add a browser exception).
I am still using Mathcad 11. And I am a fun of it.
An evident point I miss is to be able to show a result of an equation  inline with the equation itself. For instance:
x:= 5
y:= 2x= 10. Instead in my worksheets I need always to write y:= 2x   and again    y= 10.
In a worksheet that I opened recently, I found with my surprise the following equation asking from Matrix Mat_A its eigenvectors. And you can see it is followed with the "=" as I wanted.
Probably I copied from MC15 to MC11 or I did something else. I do not have recalls on how I did it. Now I am not even able to replicate it inside MC11.
Is someone able to explain if MC11 can do that. And if not, how can be explained the "exception" shown?
I can understand you like MC11 - keep it as long as possible.
I can't try as I have no working MC11 at hand and I have no explanation how you could achieve numerical inline evaluation oin MC11. Maybe @LucMeekes can help here.
Is it possible to follow an assignment by a symbolical evealuation in MC11? I guess, yes. And I think you can make the arrow look like an equal sign in MC11 as well. This may be a work around in some situations.
I can't check at the moment. But I think the only way in '11 is through symbolic definition, then followed by equals.
11-Garnet
July 7, 2017
Thanks to both for the feedback.
Symbolic inline evaluation works in MC11, as you said. Unfortunately the results are often not easily manageable in a worksheet. The same eigenvector evaluated in my initial post comes up now as  follows (I stretched the image, otherwise it would have been much longer):
Is it possible to reduce the number of decimals in this case so to make the result readable, as it appears with a simple "=" in the yellow image?
Still it remains to be understood how the original operation with "=", shown in the first post, can work in MC11.
In attachment the worksheet, with some explanations.
