Solve Blocks
agarson
Solve Blocks
Trying to use Solve for given variable in an equation but doing something wrong
LucMeekes
(To:agarson)
I think you made a mistake, it seems like you have Iw (I-omega) as a single variable, If you type them separately with a multiplication in between your solve block might work.
Do you HAVE to use a solve block, or do you just want to solve. 'cause this one is very easy.
No, do not have to use solve block but just trying them out.
Thanks for you help.
LucMeekes
(To:agarson)
Ok.
Then, did you separate the I from the omega, and did that solve your problem?
No it didn't I keep trying a few more help video.
Thanks for your help
MJG
18-Opal
18-Opal
(To:agarson)
If using the solve block, you also need to give units to your guess value of I:
