Are you fitting to data? As suggested in the prior responces? Are these exact equations and so are not acutally indepentdent? Can you solve using only the same number of equations and just check the solutions in the remaining equations? Or is this a problem of simultaneous equations with constraints? If so try using solve blocks, you can find information in Help for that.
