i would like to solve this equations. The equations are correct and testet with few parameters but to solve the complete equations is not working. Do you know what's wrong.
Thanks and regards
Why would you bother with the symbolic evaluation when a numeric evaluation gives you the results immediately - with or without the three inequalities.
Does it help to remove the three inequalities from the solve block?
Yes it works. My computer was a little bit too slow but know i have the solution.
Why is it necessary to remove the three inequalities ?
There's a dutch saying: "Vraag niet hoe het kan, profiteer er van!".
Thanks, that's a great idea.
