Symbolic Fourier Transform
payman
I was wondering if you could help me with symbolic Fourier transformation. In the attached file, I want to see the symbolic expression of i=fourier(I).
I appreciate your suggestions in advance.
Sincerely
Payman
-MFra-
(To:payman)
Hello PAYMAN,
with a bit of algebra, perhaps, you'll make it:
8 REPLIES 8
-MFra-
(To:payman)
payman
(To:-MFra-)
It is
I(k) fourier,k,z ----->
-MFra-
(To:payman)
Well! continue the calculation by yourself!
payman
(To:-MFra-)
Thank you very much.
Mathcad says that the result is too large to display
-MFra-
(To:payman)
Hello PAYMAN,
payman
(To:-MFra-)
This is very helpful. I am thankful that you considered my problem.
Payman
payman
(To:-MFra-)
Hello F.M.
Just a quick note that when you assign z1=exp(i.k.d1) and z2=exp(i.k.d2), they can no longer  be assumed as "real" at the next steps. This affects the final result that doesn't look neat.
Payman
-MFra-
(To:payman)
I'm sorry, you're absolutely right.
subsequent calculations are impossible...
I think you should review the problem again, trying  a simpler way to solve it.
