I was wondering if you could help me with symbolic Fourier transformation. In the attached file, I want to see the symbolic expression of i=fourier(I).
I appreciate your suggestions in advance.
Sincerely
Payman
It is
I(k) fourier,k,z ----->
Well! continue the calculation by yourself!
Thank you very much.
Mathcad says that the result is too large to display ![]()
Hello PAYMAN,
with a bit of algebra, perhaps, you'll make it:
This is very helpful. I am thankful that you considered my problem. ![]()
Payman
Hello F.M.
Just a quick note that when you assign z1=exp(i.k.d1) and z2=exp(i.k.d2), they can no longer be assumed as "real" at the next steps. This affects the final result that doesn't look neat. ![]()
Payman
I'm sorry, you're absolutely right.
subsequent calculations are impossible...
I think you should review the problem again, trying a simpler way to solve it.
