The usual problem with the imaginary unit.
-MFra-
Hello everyone,
What can I do to prevent this?
in order to have a result, I had to consider the operators as variables.
Thank you for all.
F. M.
(To:-MFra-)
This ist the first time in the sheet you show where you are using complex entries and so its the first time you experience the difference between conjugate or not.
I am not willing to retype but I guess you would get the result you expect if you use one of the two methods I showed above (transpose the first factor OR conjugate the second).
Regards, Werner
7 REPLIES 7
LucMeekes
(To:-MFra-)
This is what it looks like in Mathcad 11:
(I was wondering why you got j instead of i in the result:
That happens only if j is symbolically undefined.)
(To:LucMeekes)
No, you can switch between i and j in the result format dialog:
LucMeekes
(To:Werner_E)
That option is available in Mathcad 11, but it doesn't affect the symbolic results, only the numeric:
(To:-MFra-)
I am not sure why you think that Mathcad is doing anything wrong.
It correctly complies with the definition of the dot product of vectors with complex entries:
See here, for instance: -> Dot product - Wikipedia, the free encyclopedia
To get what you obviously want to see, you would either have to use the matrix product (multiply a 1x3 row vector with a 3x1 column vector) or use the conjugate of the second vector of the dot matrix produkt:
So for your first "wrong" example:
Sorry, but I don't understand what you mean by that!?
Regards Werner
-MFra-
(To:Werner_E)
Thank you for your kind attention and response that will be, definitely, the right one.
heartfelt greetings
(To:-MFra-)
Regards, Werner
-MFra-
(To:Werner_E)
Thanks Werner, you're right, it was a distraction not considering the complex conjugate. You have solved the puzzle.
  You are the best!
