This value mast be a vector
ptc-3682623
Hi
I need help because I can"t  solve my task. Please look at this situations. I need solve it vary guickly. Thanks for help
(To:ptc-3682623)
You should create a discussion/question, not a blog, to get help.
Nobody would be able to add a corrected worksheet in a blog comment.
try adding x[N=0 between the N=rows() and the for loop.
(= should be the back arrow)
until you have an array x you cannot calculate the summation of x*U
   Andy
did work in xmcd Andy?
RichardJ
(To:ptc-3682623)
When you create x[N-1 the summation requires x[N, which you have not defined. Andy suggests setting it to 0. That certainly makes the calcuation work, but you will have to decide what value x[N should actually be set to.
Thanks Richard
