On 1/25/2010 4:53:32 PM, rijackson wrote:
>On 1/25/2010 12:32:04 PM, rmix22
>wrote:
>Not only that the trace window
>stays
>empty, if I recalculate
>the
>minimize-expression it gets red
>moaning
>about "This varible is
>undefined".
>(MC14M030)
In your and
>Valery's case there is no bug. The help
>says the control string is optional only
>for the one argument case. With two
>variables and no control string, you get
>the undefined variable message. Valery's
>original example is giving apparently
>wrong answers because he has assigned
>both x and y to position 0 in the
>control string.
Without a worksheet
>it's impossible to know if pblbailey is
>seeing a real problem. Given the
>description it sounds likely, but they
>never told us which version of Mathcad
>14 they are using, so maybe all that is
>required is the service
>release.
Thanks, now I see me error!
But
0.992383364744604, 0.992383364744604
5.9923833647446, 5.9923833647446
etc
is better than
x=0.992383364744604,y=0.992383364744604
x=5.9923833647446,y=5.9923833647446
etc
for the ploting on the graph
Val
http://twt.mpei.ac.ru/ochkov/v_ochkov.htm
