Hello folks,
I've got this weird result in MC15 with the reverse function; see attached work sheet. There you'll see depicted some measurement data and the reversed values. Why on earth doesn't this function behave as in the adjacent example of Q and Y?
Any suggestions?
Raiko
P.S.
I'm using MC15 on a 64 bit Win7 machine.
Folks,
false alarm! I found the culprit, the function is working as expected.
Raiko ![]()
Oops, didn't see this before posting.
Raiko,
What was you expecting? The function seems to be working correctly to me ![]()
