Use of OCDB with Microsoft Access data bases
DeanMoore
Has anyone figured out how to use the OCDB kit? I am in the process fo converting from MathCad 15 to Pirme 3.0 and there is quite a learning curve on this. Does anyone have example files that they can share.
6 REPLIES 6
RichardJ
(To:DeanMoore)
MC15 uses a component for that, and Prime 3.0 does not have components available (neither will Prime 4.0; maybe in Prime 5.0, but don't hold your breath). Are you saying Prime has some sort of OCDB capability? If so, I couldn't find it in the help.
They have an OCDB kit that is a dll file and some exe files. They are different for both 32-Bit and 64-Bit software.
I have them looking for more examples because the info they give in the kit is a little vague.
http://http://communities.ptc.com/docs/DOC-3621
Dean
RichardJ
(To:DeanMoore)
Sorry. I don't have current maintenance, so I have no way to even look at that kit.
Where can we find this kit?
RichardJ
(To:VladimirN)
If you have maintenance, here: PTC Mathcad - All Worksheets
jsheehan
(To:DeanMoore)
The download for both the 64 and 32 bit ODBCread and ODBCwrite comes with example files and test database for MS Access.
Richard, can you send me your email?
John
