Has anyone figured out how to use the OCDB kit? I am in the process fo converting from MathCad 15 to Pirme 3.0 and there is quite a learning curve on this. Does anyone have example files that they can share.
MC15 uses a component for that, and Prime 3.0 does not have components available (neither will Prime 4.0; maybe in Prime 5.0, but don't hold your breath). Are you saying Prime has some sort of OCDB capability? If so, I couldn't find it in the help.
They have an OCDB kit that is a dll file and some exe files. They are different for both 32-Bit and 64-Bit software.
I have them looking for more examples because the info they give in the kit is a little vague.
http://http://communities.ptc.com/docs/DOC-3621
Dean
Sorry. I don't have current maintenance, so I have no way to even look at that kit.
Where can we find this kit?
The download for both the 64 and 32 bit ODBCread and ODBCwrite comes with example files and test database for MS Access.
Richard, can you send me your email?
John
